1 - 8 of 8 Posts
2020 Lamborghini Huracan EVO RWD
Dear ALL,
Has anyone changed engine oil on Huracan EVO/EVO RWD by themselves? May I ask if the engine filter Part Number 079198405E is the same as the old Huracan?
May I ask what part numbers for eight drain plug washers are? I have found the oil pump housing for the EVO is slightly different to the old Huracan. The new housing has more drain plugs. Thank you very much in advance for your help!!
Motor vehicle Car Automotive fuel system Automotive air manifold Vehicle
Dear ALL,
It sure would be nice if they made a washer kit for an oil change on the Huracan. I to am looking for washers but can’t seem to get part numbers for any of them.
Dear ALL,
Hope this helps.
1 N0138326; FC3F SEAL; 2.58
1 N0138493; FC3F WASHER M14; 2.58
3 N0138063; FC3F O-RING; 1.02
2 N0138128; FC3F SEAL RING; 1.86
1 N0138157; FC3E SEAL RING; 4.47
Oil Filter PART NUMBER: 079198405E
$73.81 each
Thank you so much for your valuable information!
2022 Huracan EVO RWD
Didn't you get 3 year free maintenance with your EVO?
Not here, but the dealer can not even find 8 drain plugs sadly
Sorry to hear that! A Lamborghini dealership, at a minimum, should be able to service a car they sold you.
1 - 8 of 8 Posts
