As it reads above, I'm attempting to remove the side skirt on the drivers side. I've already removed the passenger side which was pretty straight forward.
The issue that I'm running into on the drivers side is the oil cooler which is in front of the rear wheel as the side skirt is different. Does the oil cooler need to be removed or detached from one of the lines to remove the side skirt or will it swing out enough to remove side skirt without having to remove or relocate oil cooler? I currently have most of the oil cooler mounts off as well along with small plastic shroud on the outer edge but it doesn't seem like it would swing out away if everything else was ready to go.
Everything is loose (except for door torx bits) but wanted to figure out next steps needed before I continue. Thank you for any help in advance!! Pic shows where I'm at currently with passenger side complete.
Cheers!
Cheers!
