1 - 20 of 20 Posts
It was really easy. Once you take off the engine panel you will see the brace that bolts off and gives access.
Looks like the whole manifold has to come off? And air intake to take off manifold? Can’t see where ground wires bolt on 2, for the wiring harness in front of the engine? With manifold on
Thanks for the information. I was able to pull up on injectors and they popped out so I now have more clearance to remove the screws
Yes, it’s very tight (like most other jobs on a Lambo). But lift off the rails if you think you will get more room for the work. The fuel hoses can stay attached, so it does not have to be messy 😋
I am very curious how to get those 2 bolts out at the firewall, I am not a acrobat but it looks you have to be one 😂 And getting them in will be a nightmare too I guess…
Is it easier to remove the fuel rail ? And how can that be done ?
1 - 20 of 20 Posts
