1 - 4 of 4 Posts
I am wondering how it is possible to adjust the valve clearance on the P300 without the original tool to push the valves down and to remove the shims?
Do you guys use any trick? or a self made tool? or is it possible to push down the valve with a modified screwdriver while another person is fishing out the valve shim with a magento?
Discussion Starter #2
Is anyone else interested in such a tool??
We plan to manufacture this tool ourself...
ok, here it is:
I manufactured a cylindric part with the diameter of the bucket, which should touch it just on it's edge. Here is how to do it step by step:
1) cam is turned until the valve is fuly open
2) tool is inserted and secured with a steel plate
3) camshaft is turned back; while the bucket is still pressed down the shim is free and can be grabed and pulled out with a magent
1 - 4 of 4 Posts
