1 - 1 of 1 Posts
I read on some post here and on PH that Gallardo LP and Pre LP shares the same fluid in gra box/rear differential and front differential
But i can not see that front and rear diff are separated by long shaft.
Plus when i change both fluid rear diff fluid was almost black while front was almost new , i think last time i had changed them both at the same time.
Lamborghini specs says fluid in rear diff is GL-4 while frent diff is GL-5 and i think it makes sense as GL-5 can damages brass parts in gear box (rear diff has both gear box and diff togeTher) while front is just differential so GL-5 is what Lamborghini recommends.
I also read on PH that now since Castro’s sponsers lambo , Lambo is recommending Castrol 75W90 ?
Is that correct?
Thanks.
Ketan
1 - 1 of 1 Posts
