1 - 12 of 12 Posts
I left my headlights on, got a dead battery, jumped it and now the headlight will not turn on. Every time i put a new fuse in it blows right away. Any ideas what is shorting?
*2011 gallardo lp-560-4
try new cheap D2S bulbs just to test.
or perhaps it's the ballast (hope not, it's more expensive)
That won't help the fuse from blowing
if there is a shortcut in one bulb or in one ballast, you can put all the fuses you want, they will blow...
it's because i think all issues must me tried :
i will try a "cross test" :
Only ballast R+ bulb R , don't connect the other ballast nor bulb
ballast R + bulb L ...
ballast L + bulb L...
ballast L + BULB R...
the shortcut could be everywhere (on a wire too)...
the ballast is behind the trunk that you have to remove.
bulbs are more difficult to catch : you have to remove the wheel and the half front liner
so, if you try yourself, or you go to Lambo !
nothing to loose trying yourself (just takes time, but money perhaps)
there are new bulbs and ballast cheaper than lambo's
Discussion Starter #5
Hey Guys, Thanks for all of the input! I took it to the shop...shorted switch rack....replaced and all is good. thanks again!
how much did it cost to you ?
they change all the rack ?
Discussion Starter #9
I was pulling on the headlight switch to shut them off while I had my charger hooked to it...(200 amp )My guess is it was under or over powered which created the short.. I inspected the switches board and there is no signs of short. It is probably in one of the components on the board that is not visual. I might pull meter out and check a few resistors for fun. Glad its fixed. :)
They had to replace the full rack of switches.(all 1 piece) It was around 1500. I expedited shipping.
OMG !!!
all is always with 4 digits with lambo
1 - 12 of 12 Posts
