41 - 49 of 49 Posts
Not at all. Although there are some states where Laser jammers are illegal.
Just had the Escort 360 installed with the display in the OEM rear view mirror. Quite happy. The laser jammers sure have come a long way in terms of size. Hard to see unless you're looking for them
Reactions: LHP
I've been called worse. :)
2017 Lamborghini Huracan LP-580-2
Wow...almost everyone made this job wayyyyyy too complicated.
It’s really simple, grab you dome light on the front side by the windshield and pull that down straight. The front end of the dome light is 2 clips, the rear side has a piece that you just slide in after popping the clips.
2 of wires to the dome light are ignition, I believe the 2 on the right of the plug. Literally T-tap into those wires after testing with a volt meter. You can push the radar plug through the front of the headliner easily and it will come out by the rear mirror.
Once you try this method, I could install one in 5 minutes now and it’s a low draw using the oem fuse without any issues.
I believe the wires you are talking about is only available if you have the homelink. In my case, which I don,t doesn’t have that.
Thanks. That's how I ran it but how do you tuck the wire into this section where the red arrows are at? I can't remove that panel in order to tuck the wires into it to bring down to the bottom.
do you mind sharing how you did this / I’m on the same boat and trying to figure out how to route wires under the trims. thanks !!
BMW ///M
Great thread...following...
Sorry.. I can't remember as it been so long. I believe I just jammed the wire in slots and traced it down. Sorry I can't be of more help.
41 - 49 of 49 Posts
