1 - 13 of 13 Posts
Super Moderator
Does anybody know what the healthy range is for clutch wear readings?
An Aventador clutch is 6mm thick. 5% of that is considered part of the “break in” for the clutch. So when you look up in the computer the wear(on my car it was .9mm recently,) the wear would be .9(total wear) minus .3(break in wear) = .6 divided by 6mm. So the driver wear is 6.66% however when you add in break in wear, the actual clutch life left is 85%.
Wear divided by 6mm = worn amount.
Knowing this you should be able to determine healthy wear amount which I’d think is pretty standard on clutches. Around 10% I would get ready to replace.
Thanks
Thank you sir, that is exactly what I needed to know.
How many miles? Curious how Aventador wears on the clutch compared to Murci.
Super Moderator
Based on my current average, clutch should easily reach 50k. Why the change at 20?
I could be in the minority here but I’m interested to learn about this however never have taken apart transmissions. I presume we are looking at a clutch plate but could you explain what is looking wrong about the photo? Thanks in advance.
1 - 13 of 13 Posts
