1 - 8 of 8 Posts
· Registered
Beautiful day out started up my Gallardo-the OK light flashed on(auto check)- like normal then the driver info screen went blank-clock went out,no odometer reading,no tach reading or speedometer reading.the radio worked,and so did all the gages-except speed and tach. I shut off car
figured fuse was blown on instrument panel. Did notice panel covering for fuses was missing-(just at dealer for service). I replaced this fuse with fuse of same amp rating fuse 5 amp fuse#21.( Old fuse fell into car could not see if it was blown). Replaced the fuse then tried to start car-car turns over will not start. Looked through manual can't find anything about resetting electronics.
Car does not have alarm option.Any ideas?
· Registered
gman55 said:
thanks,
why dont they ever put this stuff in their manuals-said nothing about it when the manual talked about fuse changes-but I think it is definately security related.
Steve, if the manuals spelled out how to bypass all the security functions then thieves could simply purchase a maneul on ebay and start their own used car biz on the cheap...:)
· Registered
Definately security related (jrv you are right,just frustrated at that time)
car is being picked up by dealer this Friday-they received a zip file code from factory and this needs to be loaded into the car computer. A lesson learned, if its electronic-dont touch it!Security is too good.
ps -wiz I know where there is a 6.0 diablo
1 - 8 of 8 Posts
