1 - 3 of 3 Posts
My 06 has just pulled up an E Gear fault (generic an completely ambiguous). It does however only select first and second.
I've always had battery issues in this car and believe this may be the issue. Possibly a speed sensor fault, or my exuberant driving has removed enough of the remaining clutch.
I'd like to do my own diagnostics (as I do on my other cars). However the OBD2 bluetooth transceivers and android applications I use do not pull up EGear faults. Also given there is no historical fault codes I suspect the ECU codes are only those displayed currently.
I wondered if anyone here has a cheap solution to reading and clearing the occasional Gallardo E-Gear or OBD2
code?
Cheers, Daniel.
Sounds like it's gone into limp mode cause of your low battery. Lara or Texa will clear it. I tried everything to clear mine. Soft reset with paddles, disconnect battery for 20 mins and over night nothing worked.
Ended up buying Texa suoercar 2 mins cleared. I now have a new battery and optimizer plugged in.
I did read recently if you turn your engine on and off imediatly 3 times it does a reset. Worth trying.
Hope this helps
code?
Cheers, Daniel.
Hello Daniel mine doing the same thing bur I caused that as i was trying to make a cable for my Lara 7.0 and when I plugged it in I lost my egear and only have first qnd second unless I go in neutral qnd up shift
I was trying to upload the egear relearn but the obd2 not reading vin number with Lara
i don’t know what to do the car shifts fine when I go in neutral then up and it shift fine going down gears .... any luck ? What do un think ? I just bought A German relay after reading here on the forum, I’ll disconnect the battery and try that I guess lmk
1 - 3 of 3 Posts
