Does anyone know where to buy a Billet or Aluminum cover to replace the plastic one on the e-gear actuator? I believe mine is starting to have a small leak because nothing else seems to be leaking there.
If you send me your warped one I can make a new one. Over time they end up warping and can leak.Does anyone know where to buy a Billet or Aluminum cover to replace the plastic one on the e-gear actuator? I believe mine is starting to have a small leak because nothing else seems to be leaking there.
Anyway to make one without sending the used one? so I dont have to pull it off until I have a replacement? Also what material will it be out of?If you send me your warped one I can make a new one. Over time they end up warping and can leak.
Mark is right. That issue a new cap is NOT going to fix. I'm working on some new and exciting things with GTE and when I have it all done I'll make a new post.The black plastic cap on the back of the egear actuator is a dust cap. It covers the shift rod ends as they protrude from the housing in use. If you are getting fluid from there the orings on the shift rods are leaking.
I can get you a used factory cap in good shape if you want, for freeAnyway to make one without sending the used one? so I dont have to pull it off until I have a replacement? Also what material will it be out of?
seals can get old and leak, especially from non use... sometimes more than use. I wouldnt rule them out at all without pulling itIt would be very hard to believe it leaking from the rod o-rings considering its 6k miles.
Yes I fully understand this but some people dont understand this statement is hugely overblown, with that being said I understand its a possibility but i dont want to get into the car with just that one thing as the possible culprit. Are there any other spots that are known to leak? So far all i've heard really is the lines and these rings.seals can get old and leak, especially from non use... sometimes more than use. I wouldnt rule them out at all without pulling it
