1 - 4 of 4 Posts
Hello everybody
the 2 windows of my gallardo are only going down Now they are inside
In the 2 side the same problem
I change the control unit komfort and still the same problem
Thanks for your help (I am french so sorry if I made some English mistakes)
Hello everybody
Usually when the window doesn’t roll up or down it’s possible the switch itself is bad. I’m assume the control unit you’re mentioning is the main control switches in the center console. If that’s the case I would start at the easiest point which is checking the fuse. If not, look for a faulty wire. Last thing I see that would go bad is the window motor itself
I don't necessarily think this will solve your problem, but if you're running out of things to try, you could try cycling the windows by disconnecting the battery, waiting a bit, reconnect the battery, then try using the window switch to go all the way down, then all the way up. Again, this doesn't sound like your problem exactly, so it may potentially do nothing
1 - 4 of 4 Posts
