Hi guys im newbie to here. Got my STO 2 weeks ago n figured out the exhaust valve issue compared to my previous Performante. I ordered the Forza valve controller kit n spent 2 hours to find the right plug but failed.... anyone can really show which and where is the plug i should insert the controller in between? ur generous help much appreciate. Save my STO plz...
Forza that install menu may not suit non-engineer, maybe im over-estimate my DIY ability...
Hi,
Mine just arrived but I haven’t done it yet thou I’ve done my best to understand how to install it (which is pretty simple), apart from telling you where the exact location of the solenoid is (which I think I figured out) I’ll explain everything and if I’m wrong please do tell so I won’t make those mistakes myself as well
Plus I saw a few people couldn’t really understand the manual so once I’ll be with the car and install it I’ll add a guide with plenty of pics for other people who plan on doing a DIY.
If you don’t know how the solenoid looks search on google in advance.
So once you locate the solenoid, which I believe is located on the far right side of the engine bay kind of above the wheel well (if someone could add a pic of the exact location or explanation, it would be way easier for me/us to find it), it’s just a matter of connecting the provided long cable to the controller and to the 2 short cables, then you’ll need to disconnect the ECU cable from the solenoid and connect it back to one of matching short cables and connect the other short cable to the solenoid itself (the order doesn’t really matter), once it’s all done you’re only left with connecting the ground (green wire) of the controller to the car properly and secure everything in place and that’s about it you’re done, just put the switch on and check if the red LED is on then turn the car on and check the valves with the remote and if everything works you’re done, else check the manual for troubleshooting!
Disclaimer do it at your own risk lol thou I don’t really see much room for error, but please do read the manual as it does have a few important notes, tips and explanations!!
And a side note, I have seen that the two cables for the on off switch are exposed so I recommend sealing them off prior to the install, which I intend to do.
