1 - 1 of 1 Posts
*UPDATE
Lamborghini Exhaust - Stainless Steel Mounting Upgrade for 400251393A
We have now managed to machine and manufacture these upgraded mounts entirely in the UK and can offer them at half the cost of buying the originals - Only £150 each
1 x Single Mount - £150
Set of 2 Mounts - £300
Set of 4 Mounts - £600
We have Re-Engineered these entirely from 316 grade Stainless Steel to replace the poor quality originals that suffers from corrosion.
Replaces the following Part Numbers
400251393A
400251393
‘004432031
Re-Engineered entirely from 316 grade Stainless Steel
Caps machined from 316 billet Stainless.
Centre plate - Precision laser cut from 316 and Tig Welded.
Springs re-engineered from 316 Stainless Wire.
Internal Isolators re-engineered from 316 Stainless Knitted Mesh.
Central Bolt and Nuts - 316 - A4 Grade.
Vapour Honed Surface Finish.
We have spent months re-engineering these as i required a set for my own Gallardo but these are also fitted on a huge range of Lamborghini Models - See photo of full list attached.
If Part no 400251393A is your recommended original fitment then this is a direct upgrade. Bolts straight on.
The poor quality original Lamborghini mounts part no. 400251393A are currently £ 251+ vat each (Total Each £ 300 !) from Lamborghini and are just plated steel parts with pressed steel end caps.
Most owners upgrade their exhaust system - Why fit your system on to corroded exhaust mounts or original plated steel ones which will only degrade/corrode in time.
These High Quality Mounts are made from Marine Grade 316 Stainless - They will never corrode and always look good.
We are currently working on a 4 week lead time as they are made in limited numbers so please place your order and be patient.
Please PM your enquiries
Thanks , Nick
1 - 1 of 1 Posts
