could you post a brief comparison of how the driving experience differs from the Gallardo?
Bearing in mind that I had an 06 AWD Gallardo which was likely less refined than the LP models, and I upgraded to a RWD 580-2...
1. Huracan throttle response is more instant & linear,
especially from a standstill. Even without using launch control, the Huracan is a rocket when you simply put your boot into it. Gallardo was an utter dog from standstill
2. Huracan steering feels slightly over-assisted with diminished feedback. On the contrary, the Gallardo steering was a bit heavy & slow feeling at parking lot speeds, but very firm & direct at speed
3. The Huracan gear ratios seem much closer together and the transitions are unbelievably fast & smooth. It’s like an electric car in that you never feel any drive loss between shifts. It just
keeps going relentlessly faster & faster.
4. Even in its most aggressive Corsa mode, the Huracan sometimes omits the dramatic rev-match when downshifting, instead sounding more like a superbike “slipper clutch”, feathering engagement to slowly match RPM to the lower gear. Gallardo does a dramatic rev-match 9 out of 10 times in the same conditions
5. I don’t hear the big gulps of air by the intake on Huracan downshifts and low speed accels. Miss that.
6. The more modern Huracan cockpit imparts infinitely more quality, style, and comfort than Gallardo
7. The Huracan TC is very aggressive to the point the car feels almost underpowered when trying to accelerate hard out of slower corners. The Gallardo pulled
much harder in the same conditions. Will be experimenting soon with no TC to see if that can be resolved
8. The Gallardo felt like it over-rev’d on many downshifts, almost lurching the car forward at times. I often had to modulate the throttle manually to smooth the transitions out. The Huracan downshifts are butter smooth with 0 compensation on my part
9. Huracan exhaust sounds like a pack fire crackers going off every single time I downshift or let off the throttle, lol. I can see where some people might get tired of that, but for now I’m enjoying it. The Gallardo overrun was far more subdued & organic.
10. Rearward visibility is slightly worse on the Huracan because we are now looking through 2 panes of glass instead of just 1. There is some refraction muddying up the view a bit. Livable though
11. The HVAC squirts cold & hot water on my accelerator foot at various times, usually right after a hard right turn. I googled this and it seems like a common issue.
12. Seems like the car needs an 8th gear. Engine speed is around 3.5K RPM at 80-90 mph cruise speed. Seems too high.
