This posting is a follow on to 2 other posts regarding my ’08 Super Leggera catastrophic failure. In this episode of Bad Day in Lambo-land I cover some details of the engine disassembly, what I have uncovered regarding the failure and ask for input on potential causes. I will break this up into 6 submissions as there are a few pictures to share beyond the 5 per post limit.
I found disassembling the 5.0 liter V10 relatively straight forward to disassemble except for the one not so obvious part of disconnecting the cam chains. The specialty tools I used included a set of 12 point /triple square sockets (8,10,12 and 14mm), a set of torx bits and a set of female torx sockets. I also made the special tool for turning the crankshaft.
Disclaimer - I won’t go to the extent of saying anyone should approach taking their $54,000 engine apart with reckless abandon. I do have a bit of experience with such things and… mine is already a total loss so no real worries.
The first step in engine disassembly was to pull the intake system. Removing the intake cover revealed a mass of oil and debris that I presume was kicked up when the engine failed. See pic 1 and 2
Next step was removing the fuel rail, engine wiring and intake plenum. Below the plenum I found oil in the pockets on top of the engine. There is no feasible place for this oil to have come from and the source is yet to be ascertained. The oil filter and tubing did not suffer any leaks. See pic 3
Viewing into the intake ports revealed oil on top of several valves. The positive part of this was that it verified the valves for the 2 damaged cylinders had some degree of sealing. The bad part is that this raises the possibility of an issue with the PCV system. See pic 4 and 5
