1 - 10 of 10 Posts
In stock, ready to ship! Only one set so act fast
eplaces the restrictive factory cats with high-performance HJS sport catalytic converters for maximum performance and sound.
SOUND:
Give your Murcielago a significant bump in volume and high pitched tone with our Sport Cats. Get a more aggressive exhaust note without any increase in interior drone.
FEATURES:
  • Fits all Lamborghini Murcielago vehicles (2001-2010)
  • Improves power and throttle response
  • Saves weight from the vehicle versus factory restrictive cats
  • Constructed with Fabspeed-proprietary 200-cell HJS high-flowing catalytic converters
  • Direct replacement for stock cats
  • Constructed from mandrel-bent T304L stainless steel
  • Optimized for maximum performance with NO catalyst generated check engine light, guaranteed
  • Simple DIY (Do-It-Yourself) bolt-on installation, no cutting or welding required
  • All Fabspeed performance products are backed by the Fabspeed Lifetime Warranty
299110
Hi John,
Are these replacement for the primary cats? Also, will these fit an 2005 LP-580?
Last but not least, I have the fabspeed catback exhaust and have a pretty bad drone on the lower ranges. Will replacing the primary cats help with the drone issue?
Thank you
-G
Absolutely it will, the setup in the video runs our full bypass pipes and rear section. However, with the addition of cat delete pipes, you will get a Check Engine Light.
The best way to avoid it is by running our 200cel HJS cats, they give 95% of the flow but do not cause any emissions issues.
2005 Murcielago Coupe Gated Manual
Hi John,
Can you please send me a quote for the 200cel HJS primary cats (right after the headers) for 2005 Murci ?
Thanks
-G.
Discussion Starter · #10 ·
We are proud to announce we have partnered with the pinnacle of automotive detailing suppliers, Griots garage!
Make sure to use discount code "Fabspeed" on their website for an extra 10% off all products. Truly a match made in heaven!
Wheel Tire Car Vehicle Hood
1 - 10 of 10 Posts
