It's been an EXHAUSTing week here at Shine. Several exhaust installations have been booked during this week, one including this Lamborghini Murcielago. Our customer wanted his Murci' to sound just as aggressive as it looks. He already has a Fabspeed rear section and secondary cat-bypass installed. We are installing a primary cat-bypass made by Fabspeed as well. #LOUD
Check out the some progression and after images of the build process below!
The tear down process begins! We had to remove several exterior body pieces to gain access to the stock catalytic converters.
If you take a peek inside the heat shield you can catch a glimpse of the exhaust system.
Underneath the gigantic heat shield, we can now see Fabspeed's beautifully crafted exhaust system!
In order to remove the factory catalytic converters, we had to remove the Fabspeed X-pipe.
Removing the factory catalytic converters isn't as easy as some may think it is. We had to unbolt the motor mounts to lift up on the motor so we could get some wiggle room to remove the cats. Check out the size and weight difference our customer saved by using these by pass pipes. Not to mention, the amazing sounds it produces now!
Installing the new Fabspeed cat-bypass pipes was a breeze, because they don't have a beefy catalytic converter attached to them. Now it's time to button everything back up and hear what this V12 monster sounds like!
Enjoy these after images of this unique Lamborghini Murcielago!
Be sure to check us out on Facebook and Instagram for daily updates on what’s going on around the shop!
