1 - 2 of 2 Posts
Hi there; at the moment we got a 1974 espada 400gt and we are having problems with the ignition coils. We are located in Mexico so it’s a little bit difficult to get the original parts over here.
What I’m looking for is ti know what’s the amount of oms needed on the ignition coils for the espada.
So I can look for the coils by only knowing the oms that are needed to make it work perfectly.
Thanks a lot.
Thanks a lot.
standard omh for a coil is 1.5 or 3 ohm depending if there's a external resistor or not. you can hook up the meter to the coil and test the ohm it should read 3 with a little variant or 1.5 around there you will be able to tell because the amount will regulated by the coil so its not going to let more amperage trough then needed..
1 - 2 of 2 Posts
