I recently discovered something on my 97 Diablo that is pretty disconcerting regarding damage or warping of the engine door. I don't think I noticed it before because the top was always mounted on it. Looking forward at the left edge of the engine cover I have a gap of a about 1/2" between cover and car. In the first 18" front to back, within 3" from left edge there is a slight waviness and dullness to the paint [looks like it has been re-painted]. The dealer that sold it to me tells me now that this happens to a lot of Diablo's, especially roadsters, from excessive heat. Since I have had it I know it has never been hot enough do do anything like this. It also looks like the support hinge may be out of adjustment, but there is definitely a greater bow in the left side . [I put a pic of normal right side too] Anybody seen anything similar and what is the best fix. Thanks, Dave :confused:
I think you will find it is pretty common. Even the initial fit was a little marginal. I had my shop spend some time on adjusting things. Part of the issue is that the hinges had bent slightly from normal use. I can only give you one critical tip and that is if you start trying to adjust the cover, keep a very close eye on the front clearance ie the edge under the rear window.
-mick
wow, i hadn't heard that happening before i'm glad dhard brought this up. I'm going to have to keep an eye on mine as well.
If it is warping, maybe it is because you always kept the roof on there, and trapped more engine heat than normally would have occurred ??? :)
I think it's more that after miles & use things settle & change and they need to be "tweeked" (adjusted) to keep them in correct alignment.
At least this is my experience.
