1 - 9 of 9 Posts
2006 Gallardo SE
Found 2 plugs under the bank 1 throttle body area (right hand side of engine) that are not plugged into anything 馃
E gear car, drives fine - where should they go?
One large D shaped plug the other smaller square shaped,
Any ideas?
The one with the purple insert and metal snap clip looks exactly like the fuel injector plug. I would imagine there would be a check engine light if it was disconnected though and the engine would run rough or lack power.
2006 Gallardo SE
Only cel i get is P1426 always for both banks.
Car runs smooth and pulls like a train
Someone on Facebook said the big plug should plug into the airbox but i have fabspeed intakes so its a bit of a mystery 馃
Thanks for the reply though
2006 Gallardo SE
Just did google image search of the secondary air pump- the plugs match so thats what the Dee shaped plug if for.
Just the smaller one to work out now
Any ideas?
Did you find anything out?
I just had a look over my 2004 and found two plugs connected to nothing near the oil filter and all three plugs you show and they are cable tied up and connected to nothing so I wouldn't be concerned.
Must be for options our cars didn't come with.
Mine has the same, 04 manual
Reactions: HonkyLips
1 - 9 of 9 Posts
