1 - 20 of 22 Posts
My 06 Gallardo is stuck in neutral with NO flashing"R". I just replaced a busted line and then I bleed the system with both bleeder valves. It was working while I was bleeding the system but toward the end it stopped registering on the dash.
When i press "R" or use the shifter the pump turns on but seems to have a different sound every other time. I can hear the pump kick in but the dash does not register nor does it actually go in gear.
Electrical?
Faulty pump?
I live 3 hours from Lamborghini Atlanta and my kids have been anticipating a ride in the car to our elementary school father daughter dance on Friday the 17th.
Any suggestions? Thanks in advance
Any suggestions thanks in advance.
If pump sounds different make sure you have build in the reservoir. You may have also had a weak pump that let go.
If the actuator was the problem you would have a flashing light 99% of the time.
The system was working fine before the line burst. Then the flashing occurred until i replaced the line. I could have driven it just before i bled the system. However I wanted to make sure I bled it. It did have some air in both areas but not too bad. I believe I bled the system pretty good. It's weird that you can hear/feel the pump kick in when told too, but no action or registering at dash!
You would have to bleed the system due to a line burst as all your fluid would drain. you could have burned the pump.
I believe you are correct. The pump was working pretty hard before I realized the original problem. Then I worked it pretty good with the bleeding process. I just noticed that now it also dose not work when I open the door, so I think I did burn it up. Well at least this should be one less thing I will have to worry about breaking anytime soon. Even though with less than 5000 miles I would not have thought the line would have burst the way it did.
Anyway thanks for the help!
Discussion Starter · #9 ·
With the ignition on I went from neutral to reverse and neutral to first. A buddy loosened the screws as we did this several times to make sure there was no more air.
Looks like all the Italian restaurants have one of these in it, where u live Gvan? LOL!
Discussion Starter · #15 ·
Problem solved
As it turned out, the egear actuator had a catastrophic failure which put metal shavings through out the system. The entire egear was replaced for a whopping 25k.
Anyway thanks for the input.
> for a whopping 25k.
Can you be more specific, please?
What was replaced? The actuator assembly? Hoses? The transmission? Both?
Do you have pictures of the failed component(s)?
I ask because the actuator's E-gear fluid circuit (for hydraulic purposes) and
the transmission filled with oil (for lubrication purposes)... well, I wanna see
what failed, and which metal shavings went where.
(Back when one of my E-gear hoses failed, I got to see my actuator and all,
and I am having a hard time visualizing your failure.)
> for a whopping 25k.
When this happens the dealers like to replace the complete egear system. Actuator, pump, valve body, accumulator and lines.
Discussion Starter · #20 ·
No Warranty. Its a 2005 but has only 5000 miles.
I took the car to Lambo Dealer number "1" and he told me because I put in an off brand of fluid in the system to track down the original leak, that I ruined the system. I did not like their explanation to why they need to do a $25000 repair since the system was never operated with this "bad" fluid.
I picked the car up the next day and took in to Lambo Dealer number "2". They found the shavings and explained it to me. I probably could have talked them in to selectively repairing the system. However an egear line/pipe burst to start all of this off, so I figured to go ahead and take their recomendation and replace it all.
The old system is in the mail coming my way. I am looking forward to examining this thing.
I almost forgot how exciting this thing is to drive. I have already forgotten about the 25k. Now just looking forward to getting my moneys worth out of it, by driving it.
1 - 20 of 22 Posts
