If the accumulator is bad , would it throw a code ? Also would the pressure show normal ? According to the tech he re learned to actuator and visually inspected it along with the lines and all worked fine and psi was within spec . But in the air on the lift the car goes thru gears fine , but once lowered on the floor you get a thump noise from the car as if it is trying to engage but isn't ..... Very odd but Egear fluid is good , no leaks , actuator works according to them , clutch life is 60% ,any insight or ideas would really help . I have the Egear snapshot is there something I should look for on it specific besides clutch MM..
