1 - 1 of 1 Posts
Starts in Great Britain, Stops All Over The World
Bluestuff front pads now available for Gallardo, Huracan and Murcialeago
DP51905NDX - EBC Bluestuff NDX Trackday Brake Pad Set, EBC Brakes (ebcbrakesdirect.com)
The EBC Brakes Bluestuff NDX race formula is an ultra high friction race pad with a friction level peaking above 0.6 under braking that will generate more G force than most, if not all pads out there. NDX is capable of street use as it bites well from cold.
The big advantage of this pad is that it is one of the world's FIRST AND ONLY out of the box pre-bedded race pads that is surface "heat seared or scorched" at the factory. This gives amazing reductions in pad bed-in time on street or track. Also, being a non-metallic aramid base, NDX reduces rotor wear and eliminates the firework display spark emitted in high speed braking by competitive semi-metallics although NDX is NOT a low dust pad. There is an amount of DUST with these pads.
Disc wear is however drastically reduced and pad life enhanced. Discs wear smooth and flat without ridges.
All EBC compounds are performance enhanced with CERAMIC GRANULES making them a true premium upgrade pad range for all vehicles.
1 - 1 of 1 Posts
