1 - 12 of 12 Posts
On the way home today my car did not want to shift out of 4th gear....it would go up to 5th (with a weird rev) but would not go down below 4th. Happened on the interstate near my house.
297571
Very glad there were no traffic lights on the route.
I got it home in the garage but am not sure what to do now / next steps. It went into neutral fine.
I can hear the e-gear pump cycling more frequently than usual while sitting in the garage with the key turned halfway.
What suggestions do you have? Should I have it towed to my shop or is there something else I can try?
2008 Lamborghini Gallardo Spyder
I had a similar problem with my '08 Gallardo E-gear a few months ago. It just started acting crazy and I barely made it home. I had to keep shutting the car off and turning it back on again in the middle of the street! My local independent shop said they couldn't fix it, so I had to have the car towed to the Lambo dealer. It turned out to be the engine speed sensor transducer. $362 for a new sensor, but $1832 with labor. Ouch!
297572
2008 Superleggera
Do you have a code scanner?, I'd start there an see if it gives you any clues.
You might be losing pressure. When the system detects low pressure in order to protect the transmission, it'll pop it in neutral. The usual suspect is the actuator. The actuator might have an internal leak and that's why you're losing pressure. We see the internal leaks when we rebuild actuators
Ok thanks I'm going to have it taken to my local shop for them to check it out. I know it could be a number of different issues. If it needs a clutch I already know I'm going Kevlar and will give you a shout for a quote.
So quick update....my local shop arrived with a nice enclosed trailer today to load her up, and the car started up and went into reverse with no issues. I waited a minute and the e-gear trouble light went off and I shifted into 1st gear with no problem. The e-gear light stayed off. We loaded it up and will see what they say. I guess it could be a number of different things but I'm feeling a bit better that it shifted fine and the light went off. I'll keep you posted!
I definitely don't want to miss our invite-only Italian Cars & Coffee this Saturday in Nashville! We only have like 4 per year...
2006 Gallardo SE
Dont leave us hanging, what happened??
Discussion Starter · #9 ·
I replaced two gearbox speed sensors and the o-rings on the shifter paddles, so it was a minor fix.
$597 to replace the sensors, and $191 to replace the O-rings.
And I like that the shifter paddles are tighter now, so that's a bonus.
Did you do the work yourself? The Lambo dealer charged the other guy above many hours because they had to remove the power steering pump and oil supply pipe as noted in his post above. 1300 in labor. i’m only curious because the more of these posts I read the more I think this will eventually happen to all egear cars.
1 - 12 of 12 Posts
