1 - 5 of 5 Posts
I installed Oracle LED lights in the headlights of my Gallardo. I want the operation of the lights to appear as "factory" as possible. I'm wiring them through a normally closed relay. I want the LED's to shut off when the directionals are used. Does anyone have a wiring diagram of the directional circuit? Any help would be greatly appreciated!
You could just wire to the signal lights. Put in a relay with a off time delay longer than the light flash time. You could then go to the B contact which would keep your circuit off while the signal is on and then back on (after time delay) once the signal is turned off.. There may be a better way but this would work for you for sure.
Thanks for the information! I will look into that.
I was thinking I would have to tap into the directional circuit before the flasher.
Discussion Starter #5
I used a cutting disk on a Dremel tool to open it. Then used windshield adhesive to glue it back together.
1 - 5 of 5 Posts
