I have problem with opening my left door on my Murci LP640.
Its no problem to open the door with the outside-door-handle but when I want to open it from the inside the doorhandle does not work. Probably some mechanical issue.
Because your problem is only from the inside and not from the outside there is not likely to be any issue with the door latch mechanism and striker. Even so the easiest thing you can do first is lubricate the mechanism and see if it fixes the problem. If not, you will need to inspect the mechanical system that operates the door mechanism from the inside. To do this you will need to remove the door panel (very easy) and there are 2 things to inspect:
1. The connection between most of the linkages and the door lock assembly normally has plastic bushings on all of the points that pivot. These bushings sometimes break and cause extra play in the system.
2. Inspect the general travel of all of the linkages. There is some adjustment and it may be necessary to add a little tension to the assembly that goes off of the door handle.
Thanks for your reply/help!
I will take a look at the bushings. It sounds like it should be the problem.
Related Threads
Lamborghini Talk
743.6K posts
52K members
Since 2004
