161 - 180 of 238 Posts
I have just ordered one of these head units with wireless apple carplay, and DAB+, for a pre-LP 2007. A bit confused about whether or not the factory reverse camera can be made to work on this model car. Can anyone please clarify?
Thanks
Discussion Starter #162
Thanks
It absolutely can. Look behind your elbow for the backup camera module and that’s what you’ll need to tap into to get it working.
Ok thanks for confirming - there seemed to be quite a lot of posts, and I have got myself quite confused on the wiring for the backup camera. Is your first post in this thread the correct method even for pre-LP?
Thanks
Hello,
Look under and behind the handbrake :
If there is a module, it's easy.
If nothing: you're in my case ,you will have to use the RGB wires (look my posts about it)
Discussion Starter #165
Thanks
Yeah. I think it’s post 8 that I go into greater detail about wiring the relay for the backup cam module, but all on the first page.
The work is the same whether for Pre-LP or LP.
Who want to try ?
How to root...
Custom rom with root and a lot of mods...
i asked the HU dealer a link to download and so.. have a backup of the original firmware.
it's about 1Go
to flash like phones, just need to go to recovery and install update.zip
I just have updated the MCU with Malay mod (the free version)
Just followed the howto and that's it.
So the answer is YES we can Root the PX5.
Hello,
Thanks guys - that makes it a bit clearer, and hoping I have the module. The head unit should arrive on Wednesday.
What determines if you have the module or not? - my G is a 2007 model.
I think the camera module doesn't exist on pre LP...
Discussion Starter #169
I think the bluetooth module doesn't exist on pre LP...
I’m pretty sure he’s talking about the backup camera module, not the bluetooth one.
I wasn't drunk...
But yes i wanted to write caméra.
I have edited my answer.
Thank you Wrex
I read the whole thread, didn't see any mentioning if the rear camera will turn on if you press the button on the center console???
(radio switching to back up camera for 15 secs)
Discussion Starter #173
Post #1 and 8 go over it, but yes, the backup camera works with the button driving forward. That’s the whole reason the 6VDC relay is needed.
Discussion Starter #176
Does this cause any issues with the cigarette lighter functionality?
Not at all. The current you’re pulling from the lighter is only ever active with the car in reverse or the button pressed, but even then, the amperage being used is incredibly low.
The camera control module for the Pre LP cars in on the right rocker panel area, between the seat and the cover.
https://www.bullstuff.com/lamborghini-parts-manual/gallardo-2007-gallardo-coupe-usa/971.02.00
See the picture its on line item 22.
I see on the pic but can't imagine where it's located for Real in the car ..
Between the Passenger Seat and the door ?
On the flour ?
Anybody has a pic of it in location ?
Perhaps the diagram is not sure ?!
On my 2006 SE no module behind the tunnel near the cigaret lighter.
I Hope to find it...
I thought the RNSE was decoding the RGB Sync coming from the rear view caméra without the need of a module (because i haven't found it), so if there is for Real a caméra module but just located Somewhere else from newest gallardo's it would be great !!!
On the flour ?
you have to take out the rocker panel inner trim panel. …………...
it's not my car but you mean where i put the array ?
