Same issue dealer doesn’t even know what’s going onChecking to see if you were able to get your screen working, I am having the same issue.
Same issue! Please post what they find, it would be appreciated!Screen replacement did not work. Has to be a dealer somewhere that figured this out, I will start calling them this week.
In all the threads I've seen with this issue no one has an answer. However if it's like a C7 it's not the screen's fault the problem is called the HMI module, they are notorious for acting up, with screen free games, it created problems with a freezing screen, the radio, GPS, MP3 player input jack. I had to change mine, it's all plug and play. I bought it from a seller and you need to give him your vin so they can program it in to work. Who knows it might be similar for an H.Was there any resolution to this?
Been following a few of these threads as well, hoping someone would have found a fix and updated.In all the threads I've seen with this issue no one has an answer. However if it's like a C7 it's not the screen's fault the problem is called the HMI module, they are notorious for acting up, with screen free games, it created problems with a freezing screen, the radio, GPS, MP3 player input jack. I had to change mine, it's all plug and play. I bought it from a seller and you need to give him your vin so they can program it in to work. How knows it might be similar for an H.
