Ok Guys...
I'm not trying to defend anyones prices, however on a car such as a Lamborghini there is no such thing in the profesional world as an oil change. These cars require what is known as an oil service. In addition to draining the oil & installing the new filter the entire car must be inspected and serviced according to need. All tires must be checked for nails, wear annomolies & bent rims, suspension must be checked, entire drive train & hydraulic systems for leaks, brake pads condition, lights, belts, other fluids & pressures, cooling system operation, running condition & error codes, and then once all is inspected some responsible party must sign off that the car is good to go until the next service.
A Diablo holds almost 14 qts of
[email protected] $6.50 qt (approx.) for synthetic oil plus a filter ($25)& tax is approx. $125....
To run thru a full oil service takes even an experienced mechanic in the 2 hour range if not longer in all honesty..and that wouldn't include actually tightening loose belts that require the wing to come off for access.
