Time to time someone asks about this and how I do it, this might not be correct way to do it, but it is similar what I adjust carburetors and Diablo in it's way works like it got two carburetors.
Tool you need is manometer, it is more accurate then any other gauge you might have and it is only tool to use in my opinion, even factory manual says it is tool to use.
1. idle car so auxiliary air valves (aluminium part on valve cover each side) are closed, you can take intake tube along with air bypass tube out by now and check with mirror, through tube that valves are closed. On later cars Carter devise is not touching accelator shaft.
2. with T-connection, connect you manometer (I have four lines in mine, but two will do) to small tube that come from intake to fuel regulator, remember you need T-connection as you need fuel pressure system to work and not to leak through air anywhere, you can not just pull out one vacuum tube and let other end loose.
Here you can see how lines are connected, how black vacuum line changes to bluy pneumatic line after T-connection.
IF YOU NEED TO ADJUST:
3. close both bypass screws, brass screw under throttle body
4. adjust balance from those long bars side of plenums (remember one side got lefthand thread so they leght alteres) make it even, by adjusting BOTH sides (remember to make sure what side controls what side of engine they cross, but you get it). Adjust balance even on +900rpm, catch this low RPM with both sides throttle stop screws, so both sides are even when all slack from mechanism is resting. (find it little hard to get so low rpm, so closer 1000rpm is as good.)
5. have a friend in car lift up rpm's to 1500-2000rpm see that balance is even when accelator mechanism slack is out. adjust intake balance even as you friend keep STEDY rpm with gas pedal, it's difficult, but take time and practice. (remember to watch those temperatures, if you got issue with with cooling system you can stop any time and continue after while) use earplugs...
6. now car got air balance correct, but you still need to lift rpm to 1150rpm idle. You do this by opening up those bypass screws you closed at first; open them little from both sides and get idle to correct rpm. VERY carefully close locking nut so you do not alter balance and you do not brake threds.
(if you are not able to get balance, you have air leak somewhere, check all vacuum connections, there are plenty)
7. open one 35pin ECU connector and take connector casing out, there is a small screw at end and undoing this you can slide connector open, two rails will drop, don't worry, you get them back
Connect a multimeter to terminals 1 and 17 on the unplugged lie harness or pluged harnes like I do:
Voltage with no throttle should be 0.5v
Voltage at full throttle should be 5.0v (+ or - .5v)
(here we all should thank you "Sledge4.2" for reading original LM console for correct angle of throttle valve and using multimeter to how much voltage it is on wire, without it no-one could ever adjust idle and getting TPS sensor adjusted so ECU will know where idle is. this is one of most important service anyone have ever done to Diablo owners around world; Thank you.)
without car runing, you rotate by hand actual TPS sensor so multimeter says exactly 0.5v and bolt it carefully tigh. (bolting down can actually affect value, so keep multimeter "on" while you doing this.)
I have changed flathead bolts to hex bolts, because they are easier to use.
8. drive a bit and connect manometer back to see all is good, sometimes new angle of throttle linkage might settle in wrong. Remember to have warm car to see results, auxiliary valve mixes things up and can close little differently.
There you go, hopefully this help people to run their car without two red "check engine" -lights on dash from lean or rich mixture.
