My 2001 Diablo 6.0 vt is miss-firing at low rpm. Its been getting worse. A friend put it on his scanner, but was not sure of the codes, he did clear the existing codes. We did a smoke test, but no vacuum leaks. The engine seems to get hotter than normal. I can borrow my neighbors Snapon Solus scanner but does not have the European option and is not familiar with the generic functions. I am now reviewing online teaching aids for the Solus scanner.
I am also trying to decipher the Check Engine light history. As mentioned on Lamboweb, I turned the key off-on four times to display the codes. This video shows the dash codes flashing:
Diablo Engine Light - YouTube
I'm not sure what it means when both Right & Left flash, would that apply to codes such as the Throttle potentiometer since there is only one. I also see the Left Flashing while the Right ON ?
This what I see flashing, let me know what you think, thanks, Dave:
1) Both L & R flashes 11
2) Right only flashes 2
3) Both L & R flashes 10 ?
4) Left only flashes 2
5) Left flashes 10 times while Right is ON
6) Left only flashes 23 times
From LamboWeb.com:
Number Of Flashes Error Indication
1 Lambda sensor inactive
2 Lambda sensor detected weak fuel mixture
3 Lambda sensor detected rich fuel mixture
4 Timing sensor
5 Engine speed and TDC sensor
6 Engine speed and timing sensor signal wrong sequence
7 Air pressure sensor
8 Battery voltage
9 Coolant temperature sensor
10 Not used
11 Intake air temperature sensor
12 Throttle potentiometer
13 CAN communication link failure
14 Not used
15 Not used
16 Not used
17 Catalyst system efficiency
18 Lambda sensor efficiency
19 Misfire detected
20 Misfire detected
21 Carbon filter washing solenoid valve
22 OBDII system failure
23 OBDII system failure
From LamboWeb.com:
4 Timing sensor
8 Battery voltage
10 Not used
14 Not used
15 Not used
16 Not used
19 Misfire detected
20 Misfire detected
