1 - 1 of 1 Posts
I need to change my cv joints, so I have bought a set which was said to be for the Urraco. However the new joint has some play on the axle, which disturbs me. The old ones I had to press off. Who has got experience with that issue? Can I use any Loctite to fill the gap? Which joints are a cross fit? Maybe I was supplied the wrong ones?...
The size of the original joints are:
outside diameter: 100mm
inside diameter: 28mm (hard to measure due to the teeth)
lenght: 32mm
teeth: 25
pitchcircle: 87mm
number of holes: 6
diameter of holes: 8mm (while 2 holes have 10mm for the pin)
293054
1 - 1 of 1 Posts
