1 - 13 of 13 Posts
Can someone help with the Lamorghini p/n on the two main bolts fastening the hand brake caliper on a Countach QV?
You can't find this in the QV parts manual since it's identical to the LP5000s.
What exactly do you need?
The bolts to mount the handbrake calipers are NOT mentioned in the catalog at all...
The 25th spare parts catalog is much more detailed, it mentions on TAV 025.01 Parts 19-21
#19 8401305 Rond 13*22 C72 Secono necessita, second Washer
#20 8411303 Rond EL.A 13 Uni 1751 Lock Washer
#21 8101246 Bull D M12*1, 5*30 Bolt
terryjoint said:
Do you need the part no's from my 5000s manual ? :wave:
Terry, I have an original LP5000s part manual, the bolts are not mentioned only the entire hand brake caliper and the pads... -> TAV 23 :whip:
Hi Raymond. I am deep into detailing etc now. :eek: I have ordered special water hoses, the rocker covers are being powder coated. I have found someone in UK who will re-condition the water pump for GBP 60 and guarentee it for life !!
Etc etc, but you know all about this.
We decided not to spend a lot of money detailing the carbs, but all gaskets etc are being done here, i wish I could get the carb bodies to shine more, but at least they are clean
Discussion Starter · #10 ·
Raymond/Terry,
Thanks for your help. Yes, I need the factory p/n for the two bolts that fasten the hand brake caliper on to the rear hub. I can't find it in the 5000/QV manuals and I don't have the 25th manual on hand at the moment. Is #21 8101246 Bull D M12*1, 5*30 Bolt the same as on the QV? If the caliper has the same p/n it should also have the same bolt...Strange that it is not mentioned in the old manuals... :confused:
It's 100% the same, they didn't change the entire brakes since the LP400s (what a shame)...
1 - 13 of 13 Posts
