Yesterday I installed my MSD-Unit on a 25th Anniversary.
To check all wires I went through the wiring diagram and found the K-Terminal of the Coil to be connected with the fuel pump relais.
On the MM-Box/Coil the B-Terminal of the Coil is connected with 12V, the middle Terminal with ground and with the K-Terminal the ignition Box inducts the spark at the Coil.
But where is the sense to connect this with the fuel pump relais?
Since we got current even without this connection...
Is it to cut of the fuel when the rev-limiter stops the spark?
My car runs without this connection since I installed the MSD-Box.
Raymond
Raymond
