1 - 5 of 5 Posts
Hi, I took the Countach out for a drive today and had a little problem. My left rear blinker stops blinking when i hit the brakes (and my brake lights come on). As soon as I release the brake all returns OK. My left one works even under breaking. I checked all the bulbs and they are OK.
Any suggestions?
Thanks.
Alex
1986 Euro Downdraft Countach
Fixed - very simple solution. I took off the fiberglass/carpet cover to see the rear light connections. You can then access the rear light wiring. There are ground wires secured with connectors- I guess there was some build-up that did not permit good grounding. I cleaned them - now am good to go. :D
Hi Terry, no, surprisingly it isn't. I know that the later Countaches (the ones with the A/C on the sides of the dash) have alot of wiring in the trunk (hence problems with the cooling fans). My model year (early (86) has a "clump" of relays in the top right hand corner of the engine bay - never had to access them but it would be a bit*h to do so. Take care. Alex
1 - 5 of 5 Posts
