I need to know which hose goes where on the actuator, because on the directions I am following, it states that Lambo and Ferrari are reversed from the picture.
So is picture 1 or picture 2 correct??
"The position of the Actuator as a whole above is exactly what it would look like sitting on the side GS/4200/Quat gear box, looking down on it from the top. On Lamborghini and Ferrari they sit differently and the hydraulic lines running to the chambered openings are reversed.
You have 5 chamber banjo bolt holes. Starting at the top going left to right, the three holes are:
- The EV#3 solenoid valve high pressure line hole
- The EV#4 solenoid valve high pressure line hole
- The EV#5 solenoid valve high pressure line hole
Left to right on the bottom is
- The EV#1 solenoid valve high pressure line hole
- The EV#2 solenoid valve high pressure line hole."
