1 - 14 of 14 Posts
My car will have a few drops off coolant under the back of the tunnel after I park it. I already had the coolant lines that run around the engine replaced and the shop is now saying the lines that run front to back have developed a small leak. Can someone point my in the right direction of where I can get part numbers on these hoses and maybe a diagram of what they look like and how many there are.
Thanks a ton
Tire Motor vehicle Wheel Automotive tire Automotive design
There are a lot of hoses in the tunnel.
The coolant hoses are one of the pages 121 (4 pages) and 260_02.
I’m in the process of replacing all the coolant hoses.
291182
But start checking the hose clamps. One might just need a little tightening 😊
Correct. Hose clamps. Put it up on a lift and get up under there and tighten them. Happens every winter.
If you don’t have one, buy a flexible extension for your drill gun. Mine is around 12” long and really is important for tightening those clamps and other long reach items.
Mine has sprung the "Winter" leak this year.
Dealer says it's fine to top off the coolant with water-
Is it just as good (or preferred) to top off with factory coolant (in my Car's case Audi Blue Coolant)?
Getting at those hoses is way easier after you have converted to RWD. Perfect time to do this mod as taking the six thousand nuts out that hold the tunnel cover on, take as long to remove as removing the diff.. LOL.
1 - 14 of 14 Posts
