Coolant started leaking out of this connection. Is there a simple solution to this. These don’t seem like typical hose clamps
Shoot me a text with that same photo in it to: 717-319-2100 - I'll check and see if I have it.Coolant started leaking out of this connection. Is there a simple solution to this. These don’t seem like typical hose clamps
MarkOh and the reducer is factory fitted.
I don't have that reducer on my SL. Are you sure that's a factory thing? I think @AngelOfMurci is correct.Oh and the reducer is factory fitted.
Yes, if you look at my photo, my hose is not spliced. As @AngelOfMurci pointed out, I don't believe thats a factory part. I was wondering why this would be spliced.Guys I’m talking about the one above the splice. The one which comes off the top of the reservoir.
I agree. The splice is not factory. I’m betting it was done because the hose dry rotted and broke there as that is where mine had broken and where I spliced it until the whole hose was replaced.Yes, if you look at my photo, my hose is not spliced. As @AngelOfMurci pointed out, I don't believe thats a factory part. I was wondering why this would be spliced.
Add you on IGIf you look at the second slide you can see a fitting by the firewall. That is where one of those bleeder hoses go.
http://instagr.am/p/B9VifrKpXYT/
