This is a weird one. I have a 07' 6spd Manual Gallardo, has around 15,500ish miles on it when the original clutch let go. I bought a new aftermarket longer life clutch kit from a very recommended seller from both Lamborghini-talk and the Gallardo facebook page, and had it installed at a local exotic car repair facility, mostly due to I just got done with a massive rebuild on my z06 corvette that I did myself and had family coming into town, otherwise this something normally I would just do on my own.
The issue that I am having is that the clutch will not fully disengage to the point we actually swapped the clutch out for another one and ran into the same issue with another one of the same style clutch. The shop said they put 15 liters of fluid through the clutch system trying to bleed it trying to ensure that it was 100% bled properly. I put the car up on my 2 post at home and with the clutch fully depressed, engine running, shifter in 1st gear the wheels started to spin.
Has anyone seen an issue like this in the past? I am stumped, the shop that did the clutch is also stumped and the guy who sold me the clutches is also out of ideas minus replacing the master cylinder. We are using the recommended updated bellows style throw out bearing setup, instead of another stock unit.
Any help would be appreciated, I have search through as many posts about Lamborghini Gallardo clutches as I could find, and found nothing else to try except bleeding the clutch again.
-Steve
-Steve
