Clutch Reading
1074 1
Just had my 2006 serviced and got a clutch reading. What numbers should I be looking at for wear? I need to get the full print out from the shop.
1 - 2 of 2 Posts
Murcis: LP640 Roadster and 03 Manual Coup. LP570 Perf. Manual F355, 456, 997 GT3, Lotus Elise, Ariel
Example from an LP640: (an '06 may be different)
Auto Calibrated closed clutch position 21.4mm
Clutch Position Closed - as when new 17.8mm
Wear is 21.4 - 17.8 = 3.6mm
Assuming clutch was originally 7.6mm:
Remaining clutch is 7.6 - 3.6 = 4mm
aka 4 / 7.6 --> 52% remaining
Alternatively, Clutch Degradation Index 17,000
0-30,000 range, "replace at 15,000"
Personally, ignore the above and run to failure.
1 - 2 of 2 Posts
