1 - 4 of 4 Posts
I have a problem with my brake lights, They don't come on immediately when I apply the brake, I have to push the paddel hard to get the brake lights on.
1-Is this problem from the brake switch or something else?
2-Can I ajust the brake switch, or I have to change it?
Thanks
I have the same problem.
The reason as I was informed is that the sensor for the brake light is a pressure sensor rather than an electric switch.
So if not enough pressure is applied, the lights will be out.
You have to depress the pedal to a certain pressure before it detects that the brakes are being applied.
Dangerous isn't it. I was comtemplating converting it to an electrical switch is possible.
1 - 4 of 4 Posts
