That is what it does. It will show the error upon reseting it self.If I pull both handles to do the soft egear reset it just shows the egear error symbol.
And also eGear fluid leaked extreme (vented with LaRa?)Having just gone through this myself I'm pretty sure you're going to need to use LARA / Leonardo to properly bleed and reset the system.
Stuck in gear
Anyone have any tips on an LP560-4 stuck in gear? Let’s say you thought you blew an egear line. Then found out the pressure reservoir was the issue — was a bit loose and fluid had leaked. After topping off the fluid reservoir, refilling the pressure reservoir and bleeding the air from the...www.lamborghini-talk.com
Thats what it does
Are you sure you are resetting it correct?
Also, more important, is your battery good?
The slightest drop in voltage will make the E-Gear Error appear.
Just a heads up.
Agree with this. Unfortunately it seems that depending on where the air gets into you will need to hook it up to a proper LARA etc system to get it bled / reset. My local indie shop did this for me.I was researching this for someone else and we came to the conclusion that to do this job you pretty much had to have the car towed to a place with a LARA, or you needed to rent one. TEXA and Leonardo allegedly work, too.
Theres also bootleg lara software out there, but thats a whole other can of worms.
