1 - 14 of 14 Posts
Listen to our redesigned Aventador Valvetronic Exhaust system. We incorporated our signature X-Pipe into the new design to create a much higher-pitched V12 sound. This car was also equipped with our high-flow Sport Cats.
296304
Replace the heavy and bulky boat anchor rear cat back exhaust and get ripping F1 car sound out of your Lamborghini Aventador without losing the civility of the factory valved exhaust system with our Valvetronic Exhaust System. Featuring Helical Valves and our staple X-Pipe design that improves exhaust scavenging and gives the Lamborghini V12 a high pitched F1 wail.
SOUND:
At part throttle the valves stay closed and keep the V12 tame and easy to live with. With your foot to the floor the valves open to unleash the full cacophony of the Lamborghini V12, with the X-Pipe configuration delivering the iconic F1 high pitched wail.
FEATURES:
  • Fits all Lamborghini Aventador vehicles (2011+)
  • 3D Laser scanned and CAD designed for maximum performance and quality
  • Significant weight savings of over 20+ lbs versus the factory exhaust
  • Constructed from high quality 14-16ga CNC mandrel-bentT304 stainless steel for maximum performance and durability
  • Utilizes factory exhaust outlet tip; Fabspeed's tips sit right inside of the factory outlet for an aggressive look
  • Helical U.K. exhaust valves are aerospace quality, have superior heat resistance, and are used exclusively by tier 1 OEMs like Ferrari, Porsche, Lamborghini, Mclaren, Aston Martin and hyper car manufacturers
  • Retains factory exhaust valve functionality - Plug and play with the factory Lamborghini system
  • Complies with OEM Lamborghini warranty
  • Simple DIY (Do-It-Yourself) bolt-on installation, no cutting or welding required
  • All Fabspeed performance products are backed by the Fabspeed Lifetime Warranty
The valves: are they controllable? There may be times when as much power as possible without every cop in three states hearing it, will be desirable.
The system is fully controllable. We use strictly Helical valves, the same used in factory applications by Ferrari, Lamborghini, or Porsche in their performance applications.
Hey everyone!
Been thinking of some ways I can give back to this fabulous community, and figured there is no better way than offering you all an exclusive discount.
All Models, All products 10% off until 8/14/2021 - View all of our offerings here: Lamborghini Performance Parts, Exhausts, & ECU Upgrades
298719
Promotion through PMs and emails to [email protected] only!
1 - 14 of 14 Posts
