[email protected]
We have lightweight lithium ion batteries for most makes and models, including Lamborghini. You'll save a good chunk of weight, up to 45 pounds, just through a battery swap.
The best part is Antigravity batteries come with built-in jump starting so no more booster needed for those emergency situations. They also charge far more quickly than a traditional lead acid or AGM battery.
Given they can also handle more charging cycles, this will likely be the last battery you need.
-Lightweight, up to 45 pounds lighter than the OEM battery
-Built-in jump starting with two key fobs included
-Drop-in replacement and it's the same size as the OEM battery
-Best in industry warranty
-Incredible starting power
-3X more charge cycles than a traditional battery
-Fast charging
-Allows the car to sit for weeks if not months without a battery tender without fear the battery will go completely dead.
-Accessories include a comfort harness for easy connection to a battery tender as well as a bluetooth battery monitor which utilizes your smartphone.
-Competitively priced!
You can reach me directly,
[email protected] for a quote.
