1 - 2 of 2 Posts
I a told that the factory original hoses are not really worth a darn and if I am going to go through the trouble of replacing the hoses I should replace them with aeroquip hoses and modify the fittings to american standards as opposed to metric. I definately want to change these hoses as they are now 21 years old but I have some reservations on changing them to a non-original hose. The car is all original and I do not want to compromise its quality or pedigree, advice is very much appreciated. Thanks in advance Sincerely Vic
Vic,
I did mine about 8 months ago. I agree that the original hoses are **** hence the problem. I used aeroquip.
It is a real challenge doing them. My guy used my garage and lift. All together took him 14 man hours. I can write a detailed description of the stages if you cannot find them in the save past posts.
There are some other small parts you will need at the same time and a couple of small jobs you may as well do while you are at it. Mine is 1984, ser 12704.
cheers
1 - 2 of 2 Posts
