I am assuming there is leakage on the head gasket but hoping you guys will know something else to check that gives the same error.
It will use about 1 litre over x10 miles ie 50 miles used about 4 litres +
Any ideas ?
May be not as sinister as a gasket.... check hoses first, crack rad..... if it is the gasket then the exhaust fumes should be white....
They are when I first start it up, but not when at normal temp.
No water leakage can be seen anywhere :-(
Back in the garage (again!) now for further inspection
Check your oil level, perhaps the water is running through the gasket into the engines oil... :eek:
Well it is deffo the head gasket on the left bank, so not massive job and hopefully no further damage. Plus can be done without taking the engine out.......
Will let you guys know how it goes *fingers crossed*
