Thanks Leslie. I am just doing the ceramic coating. I don’t think the aluminum shields will be necessary. My shields were very dented and scratched. I cut them at the welds so that they could possibly be reattached but I have no intention of doing so. The stock headers seem like a good design to me. I do wish they were equal length which would change the tone but the sound of a Diablo is so iconic I’m not sure I want to change that.Wow ! What a great work . Seth, do you plan to install the header with the existing or new heat shield or just ceramic coat them ? As per Geno’s comment quicksilver carries these headers and you can order with ceramic coated version too . I am not sure will this help in term of performance and it cost 3-4 k I believe . My headers have 2 big ugly dents on the heatshield so looking at options.
Lamborghini Diablo Manifolds (1991-02)
I'm not really sure how it compares to the aluminum shields but Cerakote is said to reduce heat by 40%. All of the aftermarket headers I have seen for the Diablo have no coating or shielding so I feel like I will at least be better off than that. Has anyone here had heat issues with aftermarket headers? The fuel lines are a good ways away so I'm not too concerned about them. The wires and hoses I feel are far away enough that it won't be an issue but I am certainly going to be keeping an eye on everything to make sure nothing is getting too hot. I did add an extra layer of aluminized fiberglass heat shield over the top of the panels on either side of the engine.Seth, fantastic job. I think you need some heat shielding on those headers though. The heat coming off of there is tremendous and the aluminum shields, while rudimentary for Lamborghini to do so, prevents a lot of heat from burning up your electronics on the driver side which is only inches away. On the passenger side you’ve got hoses in the radiator and fuel supply lines, as you know. All that he needs to be pushed backwards.
I wonder it there’s a tool that allows one to place wireless sensors through out the engine bay and measure the temperatures during a lengthy drive? Sure would alleviate a lot of concerns.I'm not really sure how it compares to the aluminum shields but Cerakote is said to reduce heat by 40%. All of the aftermarket headers I have seen for the Diablo have no coating or shielding so I feel like I will at least be better off than that. Has anyone here had heat issues with aftermarket headers? The fuel lines are a good ways away so I'm not too concerned about them. The wires and hoses I feel are far away enough that it won't be an issue but I am certainly going to be keeping an eye on everything to make sure nothing is getting too hot. I did add an extra layer of aluminized fiberglass heat shield over the top of the panels on either side of the engine.
Yeah, I was thinking the same thing. There are plenty of bluetooth thermometers that would be pretty easy the rig up.I wonder it there’s a tool that allows one to place wireless sensors through out the engine bay and measure the temperatures during a lengthy drive? Sure would alleviate a lot of concerns.
Impressive! Can’t wait to hear it fire upIt feels surreal saying this but the engine is finally back in! I did it by myself so it took some time. A lot of back an forth checking things and getting it into position. Start to finish it was about 2 hours just getting into place. I wish I could just fire it up immediately and get it out on the road but it's going to be at least a couple weeks before I can get back at it.
Just a tip for anyone doing this themselves. Use a load leveler like I did. Just be sure to position it so that the handle is toward the rear of the engine unlike what it did.
