I've been having things pop up left and right lately so progress has been slow. Now that I think I have everything lined up to start assembly the bottom end I think I will start filming the assembly because I think it is a very interesting process and haven't had much luck finding any video footage of anyone doing this aside from a quick 1-2 min time-lapse.
Today the machine shop should be finishing reaming the small end bearings. I sent the injectors out to ProFlow Performance Fuel Injector Technologies for servicing. They did a full servicing on them and found them to be VERY dirty! He said he cleaned them 9 times. 3 times more than normal! The flow improved between 6-14%.
I also am treating my radiator with radiator flush to get them as clean as possible. I hooked up a pump to flow the solution through each radiator for a couple of hours each. I ran it in both directions on each one. I got a lot of sediment out but can't be certain it was not from the pump. The flow did improve noticeably on the first one which was noticeably less than the other one before I started. After that I ran cold water through to get the radiator cold. Then I emptied it and ran hot water through and emptied it again. I then quickly check the surface temps with an laser temp gun to make sure there were no abnormal cold spots that would point toward a blockage. It all seemed very gradual from the inlet to the outlet getting cooler along the way in a U shape.
