Does anyone else have this issue? Getting warning on dash but not 100% sure if it's fhe actually led strip it self or wiring. Want to make sure before I order the new light strip..is this a common problem?
So, I recently installed an aftermarket stereo and replaced the factory camera as well (I had to pretty much take apart the wing). I remember while testing the camera I forgot to plug in the 3rd brake light and I got a warning light.
It is super easy to check, carefully pop out the little "caps" on each end of the light then unscrew the 2 bolts and remove it and check the connection. To be honest, it will not get disconnected by itself because it takes some effort to unplug it, but you never know. It could be a fuse but then you would have some other non-working lights I guess (I hardly doubt there is a dedicated fuse just for that light). So, anyway, my guess is the light just gave up... they are not that expesive to replace. They even sell Chinese ones for like 40 bucks but I would buy the OEM
